fliptastic
- Feb 10, 2004
is prescott going to be a 64 bit processor? I read on a site i think that they dont come out with a 64 bit processor till 2006. Does amd really have the upperhand???
ok so intel isn't coming out with 64 for awhile, but about the mobos. Obviously amd's 64 series is amazing and way more efficient than p4's. Tho, all the mobos i look at for 64's, they have no dual channel mem for most gamerz like mwa. Should i just go along with a 64 setup and later on, upgrade to a better mobo?
Originally posted by anti
screw the prescott, when they put it to the test it had major heating issues compared to AMD, making overclocking a faint hope
Originally posted by Mad_Pyro
I am quite sure there are dual channel motherboards for Athlon64s. You cannot say that the Athlon64 does not support dual channel memory - this is just blatantly wrong. However, you CAN say that the chip's on-die controller does not support it. However, mobo manufacturers can bypass the on-die controller and use their own on-board solution, that can be dual-channel.
Prescott will not, is not, 64 bit.
It's Xeon counterpart, Nocona, will be. And they are x86-64 compatible (despite the fact Intel won't even mention x86-64 or AMD64 in their "IA32e" documentation).
We got another look at a rundown of the 64bit extensions Intel has implemented in the Prescott and Nocona cores which looks very much like it could have been a slide from AMD a few years back.
In trying to understand exactly why Intel has done things the way they have, our research has turned up a couple interesting tidbits. The Intel validation process is a grueling one (as one could well imagine would develop after something as embarrassing as the original Pentium's FDIV error). It is possible that a lack of availability of software (specifically 64 bit drivers for 64 bit windows) is preventing Intel from properly completing its validation process and enabling the hardware. We have also heard rumors that Intel couldn't enable the 64 bit extensions in Prescott without the added connections provided by LGA775. This doesn't quite seem to fit either as Nocoma won't be launching with a new socket.
Originally posted by Arauthator
The Noob Speaks:
Isn't all the Prescotts capabilites going to be done on an 800 FSB? I am understanding that it will. If so, will that make my ABIT VT7 a good motherboard for at least 5 years to come yet?
The Noob Speaks:
Originally posted by Big Worm
5 years?? I dunno about that, thats like 2009, by then we will have flying cars.
haha and robot maidsOriginally posted by Big Worm
Originally posted by Deadlierchair
EDIT: And wouldn't a northbridge-like addition of the dual channel controller kinda eliminate the point of having an on die super fast memory controller? Argh...crazy memory stuff..![]()
