Prescott 3E@3.93
speedx
Stock cooling, temps are @ 57 with load, 2x512 kingston VR, clockspeed @ 260, dram @ 400mhz, bumped up vcore to 1.47. Running a Msi 865PE-V, Timings @ 2.5-3-3-8. I am very happy with this chip what is a good air cooler to get for this setup?
CpuZ Pic
There is no need to post this in two forums...
Anyways, nice overclock. But you gotta get that to 4ghz!!! :D
What are you doing to test load on that system? Max temp of 57C on stock cooling on that CPU with that kind of overclock is insane. Is it -10C in your room?
Sejin
Agreed
Just what I was thinking.....are you running two copies of Prime95's torture test, or enough things to get/hold your cpu at a full 100% usage for at least an hour?
Unless your room temp is remarkably low or your temp sensor is WAY off I don't know how you could actually be pulling that off with the stock cooler...at least after seeing my watercooling temps on my prescott....and what a friend had for stock temps with his 2.8E.
Care to fill us in? :p
Scheizekopf said:
Yea. 4GHz!!!!!!!
It sure was fun finally having a rig clear the 4GHz mark.....and I hope you hit it to speedx, good luck. I'll be going for 4.5 - 4.7 in a few months when I'll be picking up a Phase Change setup to bring this badboy down to -40C....as even at 35C load it just won't do much more then 4.3GHz.....but I did gain 200MHz from dropping the load temp from 45-50C down to 35C.......and I just can't wait to see what -40 will bring. :D :cool:
Dillusion said:
If my 915p didnt have such a ghey sata bus lock ide get 260 fsb too :p
Hehe, I'm glad I've decided to stick with my s478 for now.....good ol' "solid" technology is still worth a fair bit of attention IMO.
Not to talk down the i915 and i925's.....but i still prefer the 875 platform for Intel right now....just seems like there's that much more market backing and history/support already in place, and it has given prices a good chance to drop over time. ;)
Congrats man :D.......I have the same exact chip and I plan to hit 4ghz on air too :cool:
I WISH I could be seeing overclocks like that with my 3.4E on air.....it's a very nice stepping on this chip.......but it's just like the FX-55 in the sense that it needs Phase Change cooling to really get going in the overclocking department. With h2O a lot of ppl are hitting about 3GHz with their FX-55's and I'm at 4.1GHz on my 3.4E......whereas PS usually yields 3.3 - 3.5 on the FX55 and 4.5+ for me. ;)
Good luck with your air cooling guys, its nice to still see some nice results coming out of a cooling setup that blows. ;)
