Presario Keyboard Error Workaround
upriverpaddler
I have a loaner box for a little while. Its a Compaq Presario. There is no option in the bios to set to halt on "no errors". Therefore the machine will not boot w/o a keyboard. I really need to run this machine w/ nothing attached. Its already hooked up to EMIII and VNC.
Whats a good workaround for the keyboard problem? Can I get a keyboard PS2 plug and short 2 wires or something?
I had one of these, best answer I found was selling it's parts on eBay...
edit: sorry no help here good luck
There's not a solution that simple tha will work. On boot, the computer sends a message t the keyboard, and the KB acknowledges with its own code. One option you have is to gut an old KB--all you need is the cord and the integrated circuit--and plug that in.
You might check and see if it has a network server mode option. This is enabled in the bios and allows at least some of the Deskpro models to boot headless.
Deskpro FAQ said:
1. enter the BIOS
2. enable the "Power on Password"-feature
3. now you should be able to see the "Network Server Mode"-feature -->
enable it
4. unplug the keyboard, save, reboot and watch the magic...(no, it won't ask
you for the power-on password)
the problem is that you won't see the "Network Server Mode"-feature without
turning on the "Power on Password"-feature.
Hopefully that helps. :D
