Prepackaged DangerDen kits??
Seems pricey for s single rad setup, and no GPU block either. DD is good stuff though. Got my Maze4 for my 6800GT yesterday and am amazed ant the fit/finish.
Hmm.. I just did a "custom A64 kit" matching everything that Tiger kit has.. and the Tiger kit came out cheaper.
what was the price difference?
do those prices include s&h?
tigerdirect has some outrageous s&h fees, not to mention they are shady with handing out rebates and on that note i wouldnt trust them with my money.
good luck :)
I don't understand how there are so many people out there talk out of their ass before knowing exactly what it is they're talking about.
I had a rebate issue with Best Buy and Circuit City before... but I DONT BLAME THEM. It's not where you buy it from that's the problem - it's the MANUFACTURER that provides the rebate... :eek: :rolleyes:
No, sometimes the retailers have specific rebates that they cover and while I've never dealt with TD myself I have heard that the rebates that are specific to their store are often rigged in such a way that you never see your money back. Which of course is one of the reasons I've never dealt with them.
Only delt once with tiger direct and had no problems. Danger Den (their online store, dealing directly with them) has been the sole source for all of the many waterblocks I have used and below is why. I have always been given very very good service and got exactly what was advertised.
While your mileage may vary, a while back they ran a specail deal for maze-3 blocks for solid copper tops becasue some of the plastic ones were cracking at the screws, a problem long since solved. Several of mine had minor cracks that did not effect the use or performance of the block but I deceided I would scarf up some extra tops and a couple of blocks anyway. There online store at the time failed to properly calculate the rebate/special on one of the items. I noticed it but felt I was taking so much advantage of their deal for people that had this minor plastic cracking issue I just forgot about it.
A month later they send me an email that their internal auditing had discovered I did not get my discount on that part and they sent me a check.
For what its worth.
hmm LOL forgot to answer the question.
If you are not the do it yourself type that is a very nice setup and other than a fan speed controller you would be set for a basic setup. The pump is very interesting. I prefer the larger rads but they are almost impossible to get into a case without major sugery and headaches. What I really like is the pump is so small you could add another for your gpu and chipset later if you wanted. The website below has some excellent diagrams on how to do that in the mulit pump users manual.
Here is some more info on the pump and the users manuals are very informative and worth a look at.
http://www.c-systems.ca
foot in mouth ok thank you.
