[[Premium Coil Whine]]
dchobaby
Finally got around to taking a few pics of my recently finished build. It's got a 5960x from a previous build. Mobo is the RVE10, and a pair of titan pascals.
The mobo lighting looks very blue in the pictures but is actually closer to a sky blue IRL. I wanted white, but the RGB lighting is far from able to produce a good white.
Unfortunately, the build isn't as silent as I hoped it would be as the Titans do whine a bit under load. I initially put together a Core P3 but needed to dampen the whine somehow. That is how I ended up going back to a Define R5.
Also notice that I ended up ditching the Corsair ML120's that I had in the Core P3. I found them too loud, producing a constant humming even at low RPM's. Ram was also changed from ballistix elites to Dominators, and PSU was debadged, lol.
