Got a Premier Pro Question.
In the past i've had a mac that i've used for video editing with final cut pro on it, and directly from final cut pro i could encode MPEG 2 and then from there go into a dvd program and make chapter makers and burn the dvd. Now i'm trying to use my newly built PC instead, i can capture and do everything fine, just wondering if anyone knows the best way to create MPEG2 for dvd use here.
My brother used to use premier a while back and he had all this super expensive programs to get it done, i was hoping by now premier would just have it built in like final cut pro, but it doesn't seem as such...
Any pointers, or any ideas on what program i could get to do this? Is is possible to install new codecs to use in premier as an export option?
Thanks! Any help is appreciated.
