Prelude occasionally looses optical connection
MetalDwarf
I have a Auzentech Prelude connected over optical to a Sony STR-995 receiver.
Every so often the prelude looses its connection to the receiver and sound stops. If i go into the audio control panel disable and enable the Dolby digital live output it reconnects. The analog connection is fine. Is this common? Is there is a fix?
