ScotteusMaximus
- Oct 2, 2005
note: steam defaults to the 64 bit code path once it updates, but you can force 32 bit by launching the game with the command "-32bit" unfortunately the 32 bit path seems to introduce corruption with water, as seen here.
i ran through various levels with fraps and cut my benchmarks right before the loading of the next portion of the level, as that drops your fps to 0 while it loads. unfortunately i don't have my regular monitor, so i can't do 1600x1200 testing. all tests were done with the machine in my sig, all settings at max, 4xAA, 8xAF, and MSAA. numbers are min, max, avg.
WATER HAZARD
32 bit:
640x480: 43, 289, 108.2
1024x768: 45, 295, 114.1
1280x960: 43, 225, 101
64 bit:
640x480: 45, 288, 113.7
1024x768: 41, 289, 113.1
1280x960: 44, 240, 101.9
it looks like there isn't much difference at all between the two code paths, at least on my machine, on this particular level, at these resolutions and settings. i'm going to try other levels that might not be as shader intensive to see what i come up with.
NOVA PROSPEKT
32 bit:
640x480: 68, 245, 123.4
1024x768: 66, 231, 114.3
1280x960: 68, 222, 105.7
64 bit:
640x480: 56, 221, 98.7
1024x768: 56, 241, 94.0
1280x960: 56, 202, 95.8
i don't know what's going on there, but i'm running them again to make sure i didn't switch the results.
edit: here are the numbers from my 2nd run through of nova prospekt.
32 bit:
640x480: 69, 237, 119.1
1024x768: 61, 230, 112.2
1280x960: 62, 213, 111.1
64 bit:
640x480: 65, 221, 104.3
1024x768: 66, 201, 103.1
1280x960: 60, 210, 99.3
i'm definitely getting lower results running the 64 bit path. so far running the 64 bit version has resulted in no difference to as much as 20 percent slower. not cool valve, not cool. hopefully lost coast puts up a better showing.
i ran lost coast with the same settings as HL2 with full HDR. i played through the entire level, cutting off the benchmark right after i shot down the second helicopter.
LOST COAST
32 bit
640x480: 32, 157, 84.0
1280x960: 31, 139, 57.3
64 bit
640x480: 21, 165, 79.6
1280x960: 12, 117, 57.2
lost coast is just as disappointing as HL2. the average framerates were within the margin of error, but look at what running the 64 bit code path did to the minimum frame rates.
WATER HAZARD
32 bit:
64 bit:
NOVA PROSPEKT
32 bit:
64 bit:
32 bit:
64 bit:
LOST COAST
32 bit
64 bit
