I've been planning a ZFS system for a while. I have 24 1TB drives for the system. I'm going to use the new Norco RPC-4224(http://www.newegg.com/Product/Product.aspx?Item=N82E16811219038). I am planning on using an AMD processor, something like this AMD Phenom II X4 925(http://www.newegg.com/Product/Product.aspx?Item=N82E16819103916) or this AMD Phenom II X6 1055T(http://www.newegg.com/Product/Product.aspx?Item=N82E16819103851) along with ECC Unbuffered RAM. What I'm stuck on are the following:
1.) What motherboard.
What's improtant for a build like this? What features do I need/want? Specific recommendations welcome.
2.) Multiple HBAs or an expander.
Where's the cost/performance split on this?
3.) Which HBA.
4.) Intel NICs
I see a lot of people saying to go with Intel NICs. With an AMD board that's not an onboard option. Do I need to consider a PCIe card?
5.) Power supply
How do I size a power supply for this?
6.) OS drive
I was thinking of this for the OS drive (http://www.newegg.com/Product/Product.aspx?Item=N82E16817997008). Any other ideas? I am planning on using a 2.5" drive for the OS.
7.) Anything else I'm not thinking of.
3.) Which HBA.
4.) Intel NICs
5.) Power supply
6.) OS drive
