hi,
anyone know a way to do the following:
I have a small network using pfsense running on vsphere and i have a few devices that have a built in pptp client that connect out to the tunnel.
on the remote end I gave the machine multiple real ip addresses to bypass the GRE limitations with pfsense.
but anyways I have a 4th device that does not have pptp client software and I need to connect it to the tunnel.
is there an easy way to do this?
also the switch that connects the clients is unmanaged
thanks for any advice
