PPD dropping?
My PPD is slowly dropping towards 0 on my SMP folding. was running 12 to 14K per day. now, its 600 using all threads at 100% wth? I've just stopped at this point, until I can figure out what the problem is.
What is giving you the PPD reading?
F@H Tracket? HFM.NET? HardFolding? EOC?
is it still running SMP? Or did it drop to classic (though even that owuld be low ... )......what unit? it could be a bad WU as well
Your SMP folding is either not running or has crashed. You have only returned 511 point GPU2 units since 9/15.
Stop the SMP and GPU and then using task manager, see if you have a process named FAH.exe or FAH_Core_xx still running. If so, kill the process, reboot and resume folding.
didn't see any remaining processes from FAH related programs, but I did just reboot from windows update, that may have killed them, restarting, will see if that fixed it.
I've seen it happen. Reboots usually fix it. I'd not, delete the work folder and queue.dat
