jpnelson83
- May 13, 2002
I'm going to be sleeving a powersupply and I was wondering if it matters if you get the two ground wires on the mollex connector crossed. For example, I take it appart and the ground that is next to the 12v line gets put into the spot for the ground to the 5v line. Theroretically the gounds are all going to go to the same place so it shouldn't matter I just want to make sure that I'm not going to screw something up but putting a ground wire back in the wrong place. Thanks guys.
