Powerstrip help.....
Frank Castle
I need to know if powerstrip will let you make a custom resolution to be used in games?I am getting 24 inch samsung widescreed lcd soon{refinance money}.The native resolution is 1900x1200 which is a widecreen resolution.Most games if any will not do that res,so I was wondering if power strip will help.I know you can make custom resolutions for windows but what happens when you go to games?
GeForceX
PowerStrip is able to change the resolutions in-game but the only problem thereof lies in the game engine. Depending on which game you play can give you the capability to run widescreen games. So, is PowerStrip able to change the resolution in-game? Yes. How to exactly force it in-game, I wouldn't know. You should do a search around the topic of HDTV. But, here's a link to the full list of the latest popular games that can or cannot run in widescreen: http://www.tigerdave.com/wgl/
Enjoy.
-J.
