Powerpoint 2013
StefanPeeters
Hello everyone,
I have a issue that I can't figure out and I thought why not post it on hardforum. When I run powerpoint the effects that I have set from going from one slide to another are not visible. For example. When I have set the transition from the first slide to the second it is not displayd. Does enyone had this issue before and can help me with it I would be thankfull.
Greetings
Try disabling hardware graphics acceleration.
File->Options->Advanced->Display-> check Disable hardware graphics acceleration
