Gollum0000
- Jan 31, 2004
Im having a very strange problem when trying to start up my computer. When I press the power button, the computer does not turn on. At first I thought I had the connector on backwards. But that isnt the case. So I keep pressing the power button, and as time goes by more components start to light up. First the ethernet adapter, etc, then the RAM LEDs and then it finally turns on. Extremely wierd.
The motherboard is a Gigabyte GA-K8NSNXP-939. Power supply is an Antec NEO 480W. There was a problem with the mobo so I RMAd that and its back. Still having this starting up issue (which was also current before I RMAd the mobo).
Something that might be important info about the mobo is this DPS GOLD unit mounted right next to the CPU. Its used for some sort of powering to the CPU. More than that Im not sure of.
CPU: AMD64-FX53
GPU: BFG 6800GT
RAM: Corsair TwinX2048-3200C2Pro
Also 2 Maxtor HDs and a dvd burner. Any ideas?
Thanks.
CPU: AMD64-FX53
GPU: BFG 6800GT
Thanks.
