runLoganrun
- Jul 4, 2005
Hey,
i'm putting in various led's in my case, but i'm not sure how to power them. they come in either 2 pin or 3 pin connectors, or some connect to 4 pin molex. How does one power the 2 pin plugs, aside from the pwr, hdd led connects? Is there an adapter available to connect these to a 4 pin plug, like several to one, or is it better to get the 3 pin ones and use splitters (don't have much left for fan connectors)?
also, does anyone have one of the mesh panel lian li cases that has done any mods to it?
I have a pc-6077 (the one with top to bottom 5.25" bays, or one of them). I want to ditch the stock hdd cage, which is a 2 bay insert that contains the power, reset, and case lights. I've installed a 3 bay one with bigger fan and now don't need the original one because I am building a file server. the 3 bay hdd cage that i installed does not have any of the switches or lights. I plan to replace the solid (empty) 5.25" bay covers with the mesh ones, and have a nice stainless steel power switch, and better led's, i need to mount these somewhere, and think a 5.25" bay cover would be the best thing.
what i want to know is what that mesh aluminum is like to drill through, if anyone knows. I also plan on putting a couple rocker switches in another cover (also mesh). Is this doable?
thanks a lot,
rlr
thanks a lot,
rlr
