Powering Issues
xOKxTrunks
I'm having some issues powering on my new rig and I'm about ready to go crazy. First off, the mobo is a Asus P5N-E SLI and the power supply is a Corsair HX520W. I plug in the power supply and the led on the mobo turns green, but when I try to power the system up, nothing happens. I have messed with the system panel connector and tried just about every way, but nothing happens after a couple hours of trying to power it on. I have tried w/ and w/o the Q-Connector, and both ways nothing happens. Has anyone had similar issues or does anyone have a solution?
You connected the other motherboard connector, right, not just the main 24pin?
If so, check to make sure (though it sounds like you already have) that your power button is connected to the right header on the motherboard.
Does your videocard have a PCI-E power cable or normal molex connector on it? Make sure it's plugged in.
Nothing like /NOTHING/ happens, no fans spin up, etc? If so, will the PSU work with another board? If not, it's bad, if yes, your board is probably bad. Before deciding this get your motherboard manual (though it's probably printed on the board) and short out the POWER SWITCH pins with a spare jumper to rule out your case having a bad switch. If the system starts after you short those pins (it won't hurt anything, just make sure it's the right pins, they should be clearly labeled) then you need a new switch, or if that isn't possible, a new case.
Hope this doesn't sound pedantic, just trying to cover everything I can think of at the moment. Also try pulling out all expansion cards but video and booting with no drives, just video and RAM to see if the PSU is being overdrawn and so won't start, though this sounds unlikely.
Can we get specs and maybe some more info in general?
Another thing you could do... If its installed in the case, pull it out and set it up on your desk. Put the mobo on top of its box (not on its anti-static bag), and plug in only the essentials (cpu/hsf/mobo/single stick of ram/psu/keyboard/vidcard/monitor). This is to insure there is nothing shorting out your motherboard. If that didnt work, try another DIMM slot, or the other stick of ram. When you run out of slots, clear the CMOS. Also try re-seating the CPU.
I've made sure all the connectors were in the right place. Nothing happens. When I plug in the power cord to the power supply the green LED comes on the mobo, then when I try to start the computer, nothing happens.
Like I said earlier, pull it out of the case, cuz it sounds like a short. While its out, reseat the CPU, too. And try all the other things I mentioned.
