powering hdd without motherboard
I'm trying to build a system that only comprises of a norco 4224, harddisks, fans, and external 8087 connectors, without the motherboard.
How do I actually connect the power supply to the casing's on/off without a motherboard?
I know you can short it directly to turn it on, how do I turn it off again? And, is there something I can buy to make this easier for me?
Is this method stable? I have heard that for the rails to be stable, there is a need for a dummy load?
Just replace the switch with a toggle type switch and wire one end to ground and the other to the green pin of the 20/24pin connector.
Don't worry about the "dummy load", the hard drives will provide enough load for the PSU to run stable.
EDIT: Or just jumper the PSU like normal and use the switch on the rear of the PSU if it has one.
Take a paperclip, bend it into the shape of a U, stick one in end a pin with the green wire and the other to any black. Now you can toggle it on/off with the switch on the power supply.
Alternatively if you want something that will let you use the front panel (buttons, LEDs, etc), Supermicro part number CSE-PTJBOD-CB2 will do the trick and costs about $30.
Wow you guys are quick! Thanks!
I was looking at supermicro part CSE-PTJBOD-CB2, and I couldn't seem to find a photo or drawing on the supermicro site (http://www.supermicro.com/products/accessories/index.cfm Chassis Panels List )
Does it look like this? http://www.mi9tech.com/Supermicro-CSE-PTJBOD-CB2-Power-Supply_p_699.html
I can't really see where I'm supposed to connect the power supply and front panel pins (I'm sure I'll figure it out when I see the board itself, but I want to be sure) And are the white slots used to power pci x slots only?
