Powering external DC fans
daba
Hello,
I'm looking for some sort of minimalistic device to power DC fans (4-pin molex or 3-pin) without use of my computer's power supply. Right now I'm using a external hard drive enclosure to power some fans, but I'd rather have something more suited to this purpose.
I borrowed my friend's
Sabrent USB to IDE converter
, but it only works for hard drives. It seems to be missing one of the rails (in between the 12V and the ground).
Anyone know of a solution, preferabbly one that they know will work? Needs to be 4-pin molex or 3-pin.
The easiest way would be to get a 12V wall wart. Just cut the connectors off the fans, cut the connector off the power supply(unless you want to buy a mating jack to make it a bit cleaner), and wire it up.
