ninjaturtle
- Dec 25, 2004
I know of the .5 amps max power draw from a USB port, I have a seagate 2.5" drive that rated at .451 amps.
Do you think the USB to SATA controller will draw more than the difference? USB drive have a JM20329 IC.
At the moment the only problem I see is at spin-up.
What is your opinion?
