Powerful lappy small form factor
MGDMN
Ok guys, im looking to get a lappy that is as small as possible but also able to play some modern games, other than crysis. I would really like to find something that is capable of playing warhammer online, SC source, and the like. I want something has a screen smaller than 14 inches. Please, point me in the right direction.
There is a similar thread here that can give you some advice. I would suggest the Lenovo X200 or the LG S210, but the LG will for sure play all your games better than the Lenovo. If you live in the US you will have to import the LG from Canada or some other country that carries them (when it comes out?).
You could always install XP/Vista on it. AFAIK there isn't a sub 14" laptop with a better GPU.
It does, but since you're gaming you're going to be using an external mouse anyway right?
Gaming on a laptop without using a real mouse? BLASPHEMY!!! :D
I think the OP needs to do some hard research on MacBooks, considering the new aluminum ones come with the Nvidia GPUs now instead of the rather lackluster Intel GMA950/3100 from the past generations.
/me is still giggling over the one mouse button comment... sorry, can't help it. ;)
Well, I dont plan to game all the damn time. Maybe, 1/4 of the time, I just want the option. So ya, I want 2 mouse buttons.
The Macbook touchpad doesn't have regular buttons. The whole trackpad is a giant button. In certain places it can be made to be left or right click.
If you were to settle for 14.1' laptops then getting a laptop would be easier.
Here's another idea for you... 10" Asus N10... $700... 9300GS, which is plenty for 1024 x 600.
Search for the Asus N10....the link I posted can't be used since the store is banned for some reason.
