PowerColor Devil 13 Dual GPU + Razer Ouroboros gaming mouse = $599 AR
http://www.newegg.com/Product/Produ...13_Dual_Core_AXR9_290X-_-14-131-584-_-Product
The also have a couple open box ones even cheaper:
http://www.newegg.com/Product/Produ...3_Dual_Core_AXR9_290X-_-14-131-584R-_-Product
This is the only aircooled R295x2 in existence, although its not "technically" a R295x2 and I'm not sure if it has zero-core tech that allows it to turn off one GPU/memory set entirely when idling, so you might want to double-check that (if it has it, its the most power efficient idling of any high end dual-GPU solution).
Specification:-
- GPU: 2x Hawaii XT
- Devil 13 Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1000MHz
- Memory Speed: 5400Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 1000W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Power Connectors: 4x 8-pin
- Display Outputs: 2x Dual Link DVI, 1x DisplayPort, 1x HDMI
- Warranty: 3yr
- Weight: 5.2lbs
http://www.guru3d.com/articles_pages/powercolor_radeon_290x_295x2_devil13_review,27.html
Review Cliffs Notes: Awesome card, insane bang/buck factor, but the cooler is noisy and not as good as the reference 295x2 watercooled solution. If you don't mind the less efficient cooler and have a beefy enough power supply and a very well ventilated case, the bang/buck factor is pretty crazy here.
Specification:-
- GPU: 2x Hawaii XT
- Devil 13 Cooling
- ROPS: 128
- Warranty: 3yr
- Weight: 5.2lbs
