Power up problems for Abit KV8 Pro
MeathooK
Abit kv8 pro, 64 3000+, booted up once..put bios on defaults...saved and exitted...nothing showed up on screen, so i shut it down, and tried to turn it back on;nothing happened, so I reset the cmos..took the battery out, put it back in, and still nothing. Then the Power On switch died..so we put the reset switch where the power switch plugs in the motherboard, and still nothing going. Anybody have suggestions?! Any help would be greatly appreciated. Thanks in advance.
-Jake
On the mobo there is a little LCD display... It tells you things about the mobo... pay attention to the numbers that come up and write them down... when it gets stuck at a number that could be the problem...
It does nothing when i push the button to make it turn on. No nothing! :mad: It DID post...then I went into the bios and loaded the defaults, and saved and exitted, and then it tried to restart...but just hung and didnt do anything...so I pushed restart...didnt restart, so I held the power button down till it shut off. I then pushed the power button so it'd come back on, and nothing happened. I reset the CMOS, took the CMOS battery out, put it back in. Nothing at all still.
If I'm using the reset switch on the case as the power switch, could that be the problem? The power switch in the case broke..so we just took it out, and put the connector of the reset switch in the place of the power switch. They're both two wires, but could that be the problem?
try just shorting the power switch pins with a screwdriver to eliminate any sort of button issues. If it still doesn't boot, then check the psu. Most boards that I've seen have an led just to indicate that they're getting power...is yours on? If you still can't get it, try paperclip-tricking your psu to see if it still works.
Ok...So just touch the power pins w/ a screwdriver, now what is "paper-clip" tricking? And how do you do it...
My kv8pro is sitting beside me waiting for distilled h20 for the cooling system since I last drained it... With the power supply on you should get the LCD reading 0.1. If its not reading that your power supply is not working or your connections are screwed up. It has nothing to do with the computer literally being on.. If your power supply is switched on you should see numbers on that.. If not again.. It is your power supply..
Yeah a power button essentially just shorts the two pins. Well you can remove the middleman and just use a screwdriver to turn the computer on and off. If you're concerned that your buttons may be defective or broken, that's a good way to check.
The paperclip trick is just where you short the green pin to any black pin on the psu to turn it on without a motherboard. The mobo just sends a signal on the green wire to tell it to turn on, so shorting it to ground accomplishes the same thing.
Oh and this may be super-obvious and dumb of me to ask, but make sure you have the switch on the PSU in the on position. Don't forget that PSU's DO have a master on/off switch.
The motherboard indicator's still on showing 01 or whatever...so I'll try shorting the pins out in a minute!
the KV8 pro also has a green LED in addition to the digital number display - I'm assuming that's on too?
Yes...both power indicators are on. I tried to short the power pins, so I put a flat blade screw driver on both of the pins, and nothing happens. So...what's the deal? :confused:
just another thing I thought of - did you do anything physically to the case or wire management? Could the wire have been pulled even slightly from the front IO panel?
I had that happen to me once - I pulled the wire slightly tighter to tape it to the mobo tray and didn't even think it would've been enough to cause any damage - so it booted up once and then nothing. A couple of times, a fan would kick for a split second and then stop. is that happening to you at all? Is there absolutely NO indication of power except for the mobo indicators?
My dad brought a volt meter home, and we tested each of the pins in the ATX connector the the motherboard, and all the voltages are perfectly fine... I can kickstart it w/ the paperclip, but I can't get it to do jack when it's plugged into the motherboard, I got a new switch for my case, plugged that into the power pins, and nothing goes...
I'm afraid that's what I'm going to have to do...I'm just makin sure that the PSU would be sufficient to run the motherboard. That wouldn't explain why it ran fine 4-5 times, then just stop. So I'm leaning more towards the RMA crap. Here's the specs on the PSU:
It's a Skyhawk PSU that came with the case. It is...Model SH-400A8H. So I'm guessing it's a 400W PSU, at +5VDC it gets 40A, +12VDC 40A, -12VDC 1A, -5VDC 1A, 3.3VDC 28A, VSB 2.5A. The powersupply works perfectly fine on an MSI KT3 Ultra, w/ AMD 2000+ XP. We just took the boards out, and tested them side by side with the same PSU...worked fine on the MSI board, not on Abit.
Here's an update on what's going on. I took the CMOS battery out and put the CMOS jumper on clear for about 30 minutes..then put the battery back in, and put the jumper back on normal. It boots up fine now, and I updated to everything the newest...newest 4in1 drivers, newest bios...etc. The problem now is, the video to the monitor just shuts off. Once while I was deleting boot disk files off the desktop, and another time when trying to access a folder on the desktop. I was able to play Doom 3 after everything was up to date for about 10 minutes, and ran flawlessly, but then deleting the files made the video crash. Whenever the video crashes, I can try to restart it, but after the windows screen...nothing comes up. I can boot up in Safe Mode, but that's about it. Any ideas? My guess is it's the PSU...what do you guys think? Any help would be greatfully appreciated.
