Power up! 30 seconds Shut down.. :-(
[v]@bans
I just finished building the following system. 20 mins ago.
http://tinyurl.com/y3ndnl
Now what happens is the system boots up, and runs for a good 30-1min, just enough time for me to get into the bios when all of a sudden.. peeeeewwwww.. It shuts down..
Everything is new so I'm wondering where do I look 1st?
Mine does the same. I have a XCLIO GOODPOWER 500W..
I am hesitant on changing the voltage setting though for fear of something terrible...
have you guys tried booting up with the bare minimum? no video card if you have integrated, one stick of ram, etc. are you using an aftermarket hsf that might not be on correctly?
I'm gonna do some trouble shooting tomorrow and see what I can come up with if anyone has any other suggestion what direction to go for this please let me know.
@ o0akoni0o:
No I haven't done that yet but I will tomorrow. Do I have be concerned about maybe screwing up my motherboard? also should I remove it from the case and put it on a non conductive surface?
why would you have to be concerned about messing up your motherboard? and yes, removing it from the case and placing on something like a piece of cardboard is a good idea.
Few questions first. I'm sure you checked out the basics, but lets do it for fun.
Is your CPU fan operational?
Did you use any thermal grease/pad?
Could be a heat issue, as most bios' will kill the computer if you hit critical temps. Just a thought. You did not state what you had tried. That is where I would start. Let us know more about your prob. and what you have tried.
I had a MSI board a while back that had a bad ambient temperature indicator. It took a little longer to shut down, but on boot up it shot up to 70c before it kicked off. A new motherboard later all was good.
But I would double check everything before RMA.
Since I've had a good night's sleep I've thought about something things..
The video card seems to be working fine since it allows me to see on m monitor so I can rule that out. I will remove it all the same.
I unplugged both of my harddrives to see if maybe that was the cause but happened so I can rule those out.
What is left is the ram, CPU and mobo
Would the way I hooked up the front panel stuff have any baring in what's happening?
I don't think it could be your front panel connections if you can power up the system and it just shuts down after 30 secs. But like you said I would try the onboard video from the DS3 and then only one stick of RAM in each of the four slots, while alternating RAM if your still getting shut off issues. Could be a bad mobo tho which you might have to RMA.
I believe that RMA stands for Return Merchandise Authorization.
Basically you call the manufacturer and say you need to return it for warranty work and they will give you an RMA number and give you more instructions on how to ship it back to them.
Please feel free to chime in if anyone has a better/correct explanation.
Thanks I'm a dummy. :p I hope not, what a hassle. Well at least I won't be out $$$.
[v]@bans;1030476984 said:
I would if the computer stayed on for longer than 24 seconds.
:p Yeah, I guess that would help... Sorry, I really feel like an idiot now...
Had the same problems with my DS3 build when the conroes came out. My RAM needed 2.1v and the DS3 (at the time) was on default of 1.8v. I think your RAM is 1.9v so I don't think that this is a big problem for you but it would be one of the first things to change in the BIOS. Also, try 1 stick like the other poster suggested.
So you are suggesting change the voltage on the ram? Interesting, just got home and getting down and dirty with the computer. Thanks everyone for all your help, I will keep you all posted on the latest..
Do you have another power supply to test out? IMO, this is the biggest source of problems on a new build.
You already said your cpu isn't overheating, so I won't ask if you remembered to take the plastic cover off the TIM on the heatsink before you installed it.:p
OK!
Whew..
OK I called up gigabyte see what input they had and it was pretty much the same everyone else had. Disconnect everything and go 1 by one adding parts.. So I did the following.
Unplugged everything, power and cables.Took out ram and as expected the computer beeped. Put in ram and it actually got worse! It would start then shut down in less time. So no alternative but to Take the mobo out of the case.and something I kind of just passed over but noticed. The case had these risers that were actually mounds. Metal mounds.I can the mobo was close enough or touching the actual case in a way that would cause a short, the mobo saw it and shut itself down.
not convinced I did that same thing on a nice flat peice of wood I had. and plugged in the parts in the following order.
  1. CPU Fan,
  2. 1 stick of ram in all 4 dimm slots
  3. Same thing with the other stick
  4. Then both switching them around in the 8 possible combination of moving them around.
  5. Added the CPU and Fan of course NO ram, got beeps.
  6. added 1 stick of ram, SHAZZAM! I was able to get into the bios No problem.
  7. Added the 2nd stick, same positive result.
  8. Then did the alternating of the dimm slots, Success!
To be sure it wasn't a fluke i left it running for a good 10-15 mins to see if it would shut off, Ran like a champ, CPU didn't go nuts, I needed to fix the voltage (which I'll ask in another forum) but aside from that It was running just fine.
I would like to thank everyone on the forums for taking the time and reading my post following my link and giving me some very insight information where to look and how to troubleshoot this.
As my final adue, I was going to post up a funny image I took but I dont' want to get in trouble so here's a link, it's just not as bad.. :cool:
http://www.mabans.com/galleries/badcase.gif
