UPDATED:
HI, so i currently have an AOPEN AX500-A power supply it says 460 Watt and 500 Watt peak.
I have tried sites like Jonyguru but i really find it very unfriendly. I typed in a couple of power supplies i am looking for and it doesn't find results.
I currently have the MSI A88X G43 motherboard with AMD Athlon X4 860K and 16GB ram at 1866 but for the love it me it only runs at 1333 i really cant believe this with today's technology, you pay so much for this stuff and its always
compatibility issues- I have actually forced my bios to recognize it as a 1866 frequency memory , not sure how this makes a difference or if it even does, i would imagine the best is if the bloody thing was recognized in the first place..... and finally have an amazing TOP of the range GTX650.
Bear in in mind 8 months ago i was still on Socket 939 with DDR1 memory and a 9800 GT....and maybe 10 month before that i was on Athlon XP 2500+ with AGP 7800. Top of the range.
My question is coming, but i am trying to give the details of what my experiences are and what i want to get to , please.
I would like to get a better PSU such as a 550Watt but then somebody told me rather get a better one like a 600 or 650 or even 700/750 Watt.
Only problem is that i am limited here with what i can get for my money.
I would really appreciate it somebody can assist me in finding one or narrowing down from what i have found.
If i could just find a simple site where you can compare PSUs side by side then it will make it easier for me.
so first off i reckon getting a good warranty would be great BUT if you guys reckon the item is so good it doesn't even need
Warranty , then ill take your word for me.
I have found these of the following which i can afford. My price range is around 1000 to 1500 Rand which is ZAR (www.xe.com)
www.takealot.co.za and www.loot.co.za are the only sites i can buy from in this scenario.
I have found these PSUs to be interesting.. I reckon i should go more than 600 Watts , so would 650 do it OR should u really go as high as 700 + :
http://www.takealot.com/cooler-mast...es-750w-semi-modular-power-suppl/PLID34188986
http://www.takealot.com/aerocool-650w-vx-power-supply/PLID41402611
http://www.takealot.com/antec-vp700p-700w-power-supply/PLID41397459
http://www.takealot.com/fsp-aurum-s-700watt-power-supply/PLID41165566
http://www.takealot.com/cooler-master-gm750w-80-modular-power-supply-black/PLID34186400 (seems like a lot of cash for me)
1500 rand is really alot of money for me but if you guys reckon it is important to have a good PSU i guess i need to byte the bullet. I was actually going to originally buy a graphics card like an RX460....
I do have future plans to get 2x RX470 graphics cards by Power Color.
I have noticed that there are a few mixed reviews on how much wattage you should have for x amount of graphics cards.
Anyways if you guys can assist me in please find a decent power supply from the list above AND HOPEFULLY it is a vital component for the PC to run efficiently ?
Appreciate you going through the list of the PSUs i found above....
I reckon for me, getting 8pin and 6 pin PCI-e, is essential as apparently you do not want to play with Molex to 6/8 pin connectors so i was told.
I wanted to ask the experts online like you guys in this community, thanks.
I would like to be running 2 graphics cards in my system with possibly a 3rd and 4th in future using PCI Risers,
I just cant afford to buy and make a mistake.... perhaps i need to get a decent 500 Watt or maybe the one i have ia already fine and it is just about me finding another gfx card now to insert in to another old Intel 775 i have... its very very slow though it does have a PCI-E slot. I also have my ancient X2 4400+ socket 939 motherboard which i can put a card in to ?
Then again do i want to run 3 machines where i can just run one which more newer technology.
