Mar 5, 2004 #1 S sn2op Gawd Joined Mar 31, 2001 Messages 685 I'd like to test this new refurb board i'm getting today without actually putting it in the case, how could I build a switch that allows me to turn it on without a case around? I imagine a switch would just fit on the usual mobo power pins?
Mar 5, 2004 #2 H HvyMtl [H]ard|Gawd Joined Dec 3, 2003 Messages 1,730 coonect the power pins with a wire or merely connect to the power switch from a case (wether or not you remove said switch from the case...)
Mar 5, 2004 #3 S sn2op Gawd Joined Mar 31, 2001 Messages 685 this would be easy for ATX.... lol ok so it seems i just need to short those pins then, a two wire setup connected to a switch should work fine
