Power Supply safe to use?
SniperXx
This Thermaltake came in my used Lanfire case and I don't know if it was already like that or what. Anyway since I noticed it I haven't been using it more than testing systems with. I just built a XP 2000+ with a Nforce 2 IGP mobo,160gb,2 optical drives 1 case fan and 512mb PC3200. No high end 3D cards will be used. I tested with my multimeter and it shows 3.39 which should be good.
I am guessing it go poor connection with a motherboard and got hot maybe? Or maybe the guy I got it off of tried to push his memory voltage high? Isn't this line mainly used for memory?
Pics:
http://img444.imageshack.us/my.php?image=picture0041of.jpg
http://img157.imageshack.us/my.php?image=picture0080te.jpg
http://img444.imageshack.us/my.php?image=picture0099dj.jpg
Just wanting to know if this power supply would still be safe to use on a low/mid end system. Whats the worse it could do if I use it?
Probably just a poor connection or bad ground. Clean the contacts and you'll be fine.
how would I go about cleaning it? Can't really get anything down in there.
Just a pick. Just to clean some of the carbon off of there. If you have electrical contact cleaner, spray it on it.
