shadow-13x
- Sep 23, 2003
A friend has a KT7A-Raid mb/AMD Thunderchicken 1.0 with a 300w power supply. The power button on the front does not start the computer anymore. I took the 20 pin connector off and jumped green and black, and it does power up and the CD/hard drives spin up and run. I thought ok, bad switch. Cut wires off the back of the switch and touched them together, nothing. Then I took a paper clip and wedged it into the green and black on the back of the 20 pin molex and plugged it into the MB. Then flipped the switch on the back of the PS and computer started and ran. Is this a bad MB? I'm thinking that the front power button was doing it's job, the start signal never made it back to the PS. Am I right, or way out in left field in the rain?
ThE sHaDoW
ThE sHaDoW
