Power Supply question ...
Siriusmuzik
Does anyone have the link to the website that helps you determine if a certain wattage is sufficient enough?
Thank you !
Post the system specs and let us know what PSU you plan on buying, just so we can make sure you're getting the most bang for buck for your needs. ;)
