Power Supply Question
Buntz
My power supply CPU voltage drops when I put my CPU at max loads. Is this normal? It goes from 1.488 to 1.456 when I run two console of folding@home,it also does it when I run Orthes. Both cores are at 100% when this happen. The computer is overclock to 2710 MHz [271 x 10] right now.
I would consider this normal, I also have an ever so slight drop in my CPU voltage when I push 100% trough the cores (about 0,01v), you shouldn't be concerned IMO...
Thanks Darth Bobo for the reply. Just wanted to make sure it was normal.
