Power supply question P5N32-E sli
sammy sung
I'm just wondering about my psu,when i ordered this system i had originally booked a 7950 gx2 but they didnt have any in stock,during that time the 8800 gtx was released so i ordered one of those instead.While the Tagan easycon XL 600 w psu i have was enough for the gx2 i'm wondering if it is enough for my single gtx.I am aware of the fact that i cannot run a sli system with 2 gtx cards with this psu but i'm not planning to do so either,i just wanna make sure it will cope with this rig.
Now for the small issues ive been having that i prior to this attributed to immature gfx drivers or ram.Most games run great,smooth as silk with great fps,tested all the 3dmark versions from 2001se to 06 with results within specs of this setup (50k 2001se,36k 03,16k 05 and just over 10k in 06.
The exceptions sofar are rainbow 6 vegas.Although the game runs fine,good fps and so on it will eventually lock solid,the screen gets garbled and 9 times out of 10 the machine reboots with a bsod.UT2004 sometimes refuses to start and returns a nv4 dll error (or something similar) and changes res and desktop colour to 640x480/256 colours.Its not a gfx temp issue,the card is never near overhating so perhaps it could be lack of power?
And then to overclocking,whatever advice and settings i try it isnt stable above 2.7ghz wich puzzles me,it wont even boot to desktop over 2.8 ghz.Everyone seems to reach over 3 ghz quite easily with this board/cpu wich again leads me to belive i need a psu with more amps on the 12v rails,tagan claims it to be sli ready but a single 8800gtx might need more power alone than 2 7900gt ?As far as i can tell from the manual it has 4 12v rails that each gives 20 amps(combined 48amps)
Any advice would be helpful
