Power Supply (PSU) simple question
Pocatello
DC Moderator and [H]ard DCOTM x7
Staff member
Does a PSU supply power when it is plugged in? I just bought a new Fortron PSU for my project 40Ghz Xeon. Anyway, that is off-topic.
So I have it plugged in to AC power, but not hooked up to a computer... and no fan noise.
I hooked it up to two hard drives connected to another computer with a separate PSU... and nothing. (The other computer boots fine, but did not recognize my two hard drives.)
Are PSUs more sophisticated than I had guessed? Do you need the PSU to be hooked to the motherboard with the big-ass connectors to get it to work at all?
In case you are wondering WTF I am trying to do... here goes.
I have a 400gb HD and I need to copy the info to another 400gb HD. But I am short on computers that have native SATA power supply connectors. And I had this brand new Fortron $90 PSU just sitting there waiting for Project 40ghz Xeon. The Fortron has two SATA power connectors.
Thanks for your help!
you have to short two of the wires to jumpstart the PSU (that's the job the motherboard would perform...)... I think there's a how-to in the PSU forum..... Or Spectre could jump in ;-)
Keep on Folding!! For the [H]orde!!
Green to black. Yeah there is how to somewhere here also. If there is no load even shorting some PSU's won't turn on but with a couple of drives it should be good to go.
Wow!
in less than ten minutes, I have an answer plus a picture!
Thanks!
