I have an old build that I would like to get running again to use as a simple home server. My girlfriend stopped using the computer because it used to randomly restart. After doing that for some time, it would restart, then would not stay on for longer then a few seconds(if you left it off for an hour or so, it would run for a little bit, but do it again after a period of time). I think it may be the power supply, but not entirely sure. Does this sound right to any of you?
Heres the specs:
C2D e6600
Gigabyte DS3
2 Gigs XMS2 800
8800GT
Antec Earthwatts 430W psu
If the power supply is most likely the problem, which would you recommend? I'd prefer something on the cheaper side(relatively speaking, good quality, but nothing unnecessary), and efficient(if that is determined by the power supply).
Thanks in advance for any help.
Heres the specs:
C2D e6600
Gigabyte DS3
2 Gigs XMS2 800
8800GT
