power supply opinion please
anime4u
My computer generally runs from 150 watts at idle to about 250 watts at load. My specs are in the sig. I was wondering if there is a powersupply "sweet spot" (lest power draw, best power deliverance) I should be thinking about. Any opinions?
Thank you in advance!
To get the best efficiency out of a PSU, you'll want to be between 30-70% of the max load of the PSU.
150W is 30% of 500W
250W is 50% of 500W
150W is 33% of 450W
250W is 56% of 450W
For your situation, a good 450W-550W would be best from a noise and efficiency standpoint, I recommend Corsair, of course, but then again I'm biased. :)
Thank you for the info. I am also considering trying Corsair power supplies. I know they perform well.
