Freelancer91
- May 23, 2009
I have a Powork 680 watt power supply as part of my custom PC build. It was my Christmas from my parents instead of the cellphones my siblings got. It provides plenty of power and is very reliable, but there is one issue that is bugging me. Whenever I power my computer on after it has been off for a while (like if I have been at class all day or if I turn it on in the morning) it makes a weird humming/whirring sound. It is loudest right after I start the computer and dies away after a minute or two. If I then power off the computer and immediately power it on again, there is no sound. The computer experiences no power issues upon startup. I have checked the fan intakes. They are clear. I have not opened up the power supply itself as I do not want to potentially damage the supply because I don't know what I am doing. I don't think my dad got a warranty with the power supply (probably got it off ebay). There was a time when it didn't do this, but now it does it every time I do a cold start. My suspicion is that leaving it off for a while allows some part of it to cool down, when I start it this part has cooled enough so that it has shrunken. It then doesn't quite fit into something properly and must heat up again until it fits in. Is there anything I can do to stop it? I am at the University of Illinois Urbana Champaign and am in the ECE department. If I knew what I was doing, I could take it into the machining shop and fix the problem.
