power supply, mobo, or video card problem?
Hyperion0
Edit: even though the motherboard was saying my +5v line was fluctuating between 2.8v and 4.8v, i checked out the PSU with a real voltmeter and all the lines were fine.
Edit: This computer can run prime95 without errors for days. It only crashes under the following circumstances.
I'm using an old Gigabyte socket 939 nforce3 board, with a radeon 9600xt (agp8x). I heard radeons and nForce boards tend to not work well together.
In graphically intense games (world of warcraft) sometimes it works fine for many hours, and other times the GPU crashes and recovers several times in the span of a few minutes. Also sometimes textures and vertexes get persistently corrupted and the only fix is to quit the game and reload it. This made me think it was a GPU cooling issue... I haven't verified that the gpu heatsink is properly seated or done anything to it out of box.
Other times during games it just outright freezes and I have to restart the computer. This could be a GPU issue, or something completely different.
Sometimes when the computer is idle for hours, doing nothing, it will crash and then try to reboot and the BIOS won't be able to detect the presence of any hard drives to boot from. This obviously can't be the video card's or the OS's fault. Just restarting the computer fixes this and it autodetects fine.
In graphically intense games (world of warcraft) sometimes it works fine for many hours, and other times the GPU crashes and recovers several times in the span of a few minutes. This made me think it was a GPU cooling issue... I haven't verified that the gpu heatsink is properly seated or done anything to it out of box.
Sometimes when the computer is idle for hours, doing nothing, it will crash and then try to reboot and not be able to find the hard drives to boot from. This obviously can't be the video card's fault.
Maybe something is messed up in windows. What are you running?
I'm running windows XP, with all the updates. I've changed ATI drivers 10 times with no effect.
