Power Supply & MoBo Issue
yes and no. yes i think it might boot up but you will have stability issues, its just not enough power. plus it has no pci-e so how are you going to get enough power to the cards? I told you about the forton in the other post.
Then NForce4 boards require an ATX 2.0 spec PSU which has the native 24 pin ATX mobo connector along with the 4 pin 12v. It should also have the new 6 pin PCI-e line for the new video cards. I"m not sure if a 20-24 pin adapter would work in this scenario. But, would you really want to risk your new hardware by trying it? Keep reading (particularly the Sticky's) in this forum and you'll soon know what to replace your antec with.
