Loaded Glove
- May 15, 2016
When I power the system on/off, reboot and also sometimes in certain load scenarios, the power supply makes a single loud click. The sound is not continuous or sustained, just a single loud click.
I've Googled and get mixed opinions on the issue and it's driving me crazy so I hope to find some help and info here.
First I bought a Corsair HX1000 and had this issue so I returned it to MicroCenter and since they had no more in stock, I swapped it for an EVGA SuperNova 1000 P2. Both units have the same issue so I have to think it's either normal, being caused by something other than the power supply directly or I just have terrible luck.
The issue persists with or without the graphics card installed. Since the 1080 is power hungry, I thought taking it out and using the onboard would be a good variable to try.
I'd like to know what this is, if it's normal or not and either way, if I should get another unit immediately.
Thanks in advance for any help and information!
Specs
intel i7 6700k (no OC)
Asus Maximus VIII Hero* (bios 2001)
Corsair Vengeance ddr4 xmp 2666 32gb (16x2, qvl*)
msi GTX 1080 Gaming X Twin Frozr VI
Samsung 950 Pro M.2 NVMe 512gb
Hitachi Deskstar 7K4000 2tb x 2 (independent)
NZXT S340 matte black/blue
EVGA Supernova 1000 P2
BeQuiet! Shadow Rock Slim (135mm slim fan)
Cougar CFD120 x2 intake, NZXT FN V2 120 x2 exhaust
Windows 10 Pro 64bit
Specs
