I just did a little upgrade - from corsair value select 1GB memory to 1GB GSkill's (in sig). I used to OC (with value ram) to 212 w/ 12x multiplier, and had no problems. Now, with the new memory, it doesn't want to OC past 218x11.
It'll only post from a hard wake-up with low voltage/frequency settings (218x11), and from there I can push it a little bit (225x11). From there I go to give it more volts, and the system won't POST upon a restart. Now, after a full BIOS reset, I bring up the original settings (218x11) and it works, and it'll go to 225x11, it'll work, but it won't do a cold/hard start (no post).
Being that I have 4 HDDs, 6800GT, 4 case fans, and an old 420W Purepower, I think that a new power supply would help. (plus my current 420W is a 20-pin, and the mobo is 24).
I'm thinkin that I need as much as 500-600W, so would a Enermax Liberty 620w or a Ocz Powerstream 600w do the trick?
thanks
thanks
