Here is my system:
MOBO: Abit - KV87-Max3
CPU: Amd 64 3200+
Video: Radeon 9800 Pro 128MB
Ram: 1 x PNY 512MB 2100/2300
1 x SourceTek 512MB 2100/2300
HDD: 1 x WD 20GB HDD
1 x WD 80GB SATA HDD
PSU: DC output: 400W MAX
Input - 100-127V~10A 50/60Hz
200-240V~6A 50/60Hz
Output - +5V/30A Max. +12V/25A Max.
-12V/0.8A Max. +3.3V /28A Max
-5/0.3A Max +5Vsb/2.0A Max
(as you can see i pretty much just copied the label)
My computer is having an issue. At a point when i am doing something my computer will just shut off. The reason i feel that it is the power supply is 1) it just shuts off, not restarts, shuts off. 2) Thats the only thing i havnt changed around with diff parts to see if that still happened. yes i am somewhat of a newb when it comes to power supplies, but i figured this is what i think is wrong, so maybe you power supply buffs can help me determine whether or not this psu is sufficient, if that is my problem or if you may know of a diff reason with my current setup. It would be greatly appreciated. Thanks
-Zanghor-
CPU: Amd 64 3200+
200-240V~6A 50/60Hz
-Zanghor-
