Power supply good enough? (enlight)
Worminater
I have an Enlight 420w power supply, model EN-8420934
My comp is currently a7n8x-x w/ xp2000+ and a bfg 6800gt oc.
kThis setup is running perfectly stable at stock speeds on the enlight psu
I just ordered MSI "K8N Neo2 Platinum" (nforce3 ultra) and an a 939 3000+ chip to put in it, w/ a gb of muskin. Will this powersupply handle my system fine? Heavy cathode/led usage in case currently, but wattage shoudlnt be problem... ive read that certain enlights are good, is mine good enough...?
*bump* was bout to hit second page:p No one can tell me whether I have a good enough psu or not?
Probably.
If you get instability problems, get a new psu.
Look thru the FAQ, I think there's a calculator.
yes it will handle it.. not like ur throwing in those things plus a 6800 ultra or anything.. i am suffering over here with my antec 450w ith 20amps on the 12v....(overclockingwise)
but stock speeds are more than perfect..
