Ok well that constitutes a bad night.
Using a Gigabyte K8NS motherboard with a Athlon 2400+ being run by an Antec 450 Watt Power supply. Everything is plugged into a Belkin battery backup/suppressor.
I come home from work one day and nothing is running. Odd, battery back up is running, monitor is running, everything plugged in correctly, no odd smells in the air. Hitting the power button on the case though brings no reaction from the power supply whatsoever.
Ok, no worries, bad power supply. Buy a new Thermal Take 600W, slap it in. Well it turns on momentarily and turns off.
Ok, I've seen this before, I can handle it. Test my memory sticks one by one, unplug non-essentials, make sure all essential items are firmly plugged in, make sure my CPU is firmly seated, no dust on back of motherboad to short out against the case. Looks ok... contact!!
Big bang from the power supply, a whiff of ozone, and it's dead.
The good thing is I didn't throw anything, the bad thing is, I'm clueless. I'm assuming the power supply did what it was supposed to do in order to protect my computer.
Any thoughts are appreciated.
btw, both the 24 pin, and the 2x2 were plugged in
Some new info after interviewing the wife and kid. Last it worked, we were ripping a DVD through which the computer was intermitently getting sluggish. That could be due to the CPU usage of ripping a DVD, but I don't think it's ever been sluggish before when doing that.
Apparently though, the same thing happened to my original Antec power supply though while I was at work, it blew it's top.
I'm wonderin if this could be a problem with the video card which has it's own power connection.
