Power Supply for new rig?
seamorgh
My specs so far:
MB: GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359
RAM: OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227289
HD: Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
CPU:Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
Probable video card: MSI N260GTX-T2D896 OC GeForce GTX 260 896MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127361
Will the Seasonic S12 II 380W be sufficient?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151032&Tpk=Seasonic S12 II 380W
If not what's another silent psu that you can recommend?
I wouldn't recommend cutting it that close for a GTX-260 system.
Why specifically are you interested in the Seasonic S12 II? There's a lot more powerful, and in some cases better, power supplies out there for a lot less money.
I began my build using arstechnica's guide http://arstechnica.com/guides/buyer/guide-200809.ars/3. But I've probably made enough modifications to need a more powerful psu.
I want to go with a P182 for my case so this rules out PCP&C.
I am leaning towards the "SeaSonic S12 Energy Plus SS-550HT 550W": http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16817151027
Seasonic has very good reviews from silentpcreview.com
Uberbob102000: The BFG seems like it's unreliable from newegg reviews.
This is unrelated but:
I am also curious about what you guys think is a better deal?
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
User reviews on sites like that are posted by a bunch of random internet fuckwads, with no credientials, and are just angsty shit. Additionally, most people who have positive experiences dont' take the time to post feedback. I mostly ignore them.
Check Hard's review of the BFG ES800.
If it was me, I would pick one of these two, nice deals when factoring in the MIR.
1. http://www.newegg.com/Product/Product.aspx?Item=N82E16817702007
2. http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Not a bad deal either if it would come back in stock:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
It's Newegg reviews anyone with a keyboard can write one without knowing what they are doing which is typically the case. One of those reviews BTW was someone complaining about a mounting bracket...that would have come with the case they were using if necessary. Yeah.
Regarding your video card choices. I typically look for better warranties (BFG, eVGA, and XFX) rather than dealing with the taiwanese companies. I have had lots of videocard failures from ATI and nVidia based solutions.
I lean toward BFG. Lifetime warranty, US based support, AND they are upgrading one of my old AGP cards to a PCIe card. <3. Don't know how they stay in business.
just to follow up,
I decided on the BFG PSU.
And for the vid card i went for MSI, it was too cheap to pass up at $160 (after promo code) and mslive.
Thanks for the recommendations.
