Power supply for first build
Stias
Good afternoon all,
I am doing my first build and want a 750W power supply but am torn between the Seasonic focus plus 750W 80 plus gold at 150$ ( the 850 is only 160$) and the Corsair Rm750x 750w 80 plus gold ( 2018) at 160$.
With your knowledge can you answer which I would most likely get the better use out of between these power supplies.
I can attach the links below:
https://www.microcenter.com/product...t-80-plus-gold-atx-fully-modular-power-supply
https://www.microcenter.com/product...plus-gold-atx-fully-modular-power-supply-2018
What does your rig consist of? Without knowing your components I would go seasonic 650 focus plus and save a few bucks. Most 750w psus are overkill for the majority of systems.
I would echo these sentiments. Unless you are running multiple GPU and A LOT of other hardware, it is pretty unlikely that you will need anywhere near 750w. Seasonic and Corsair both make good PSUs. Save a few bucks!
