Power Supply for corporate file server
Sasiki
The economy isn't allowing me to spend a lot of money on a file server for work, so I'm building my own. I'm going to use an Asus P5BV-E motherboard, quad core CPU, 8gb ram, and 4 x 640gb hard drives. In the future, this machine will likely be a VMware box with increased hard drive numbers. I would like to buy a decent power supply since the server will be on 24/7. I will be building another server for a branch office using the same motherboard and power supply so I am going to buy 3 power supplies and motherboards, just to have an on hand spare. These are the 2 thing most prone to single point failure. The hard drives will be in Raid 10.
Depending on the price of the power supplies, I may just spring for a nice server case that already includes them since I have to buy cases too. One will be a 2 or 4U rackmount and the other a tower server.
Any suggestions on either?
For your tower any modern "known good" Single Rail 400W+ PSU, should be fine.
BFG Tech LS-450 450W
+3.3V@24A,+5V@20A,+12V@29A,-12V@0.3A,+5VSB@2.5A
$50: http://www.newegg.com/Product/Product.aspx?Item=N82E16817702014
Corsair CX400 400W
+3.3V@20A, +5V@20A, +12V@30A, -12V@0.8A, +5Vsb@2.5A
$43: http://www.buy.com/prod/corsair-400...r-supply/q/loc/101/209253909.html?dcaid=15891
PC P&C Silencer 420 ATX 420W Rated@40C
+5V @ 20A, +12V @ 30A, -12V @ 0.8A, +3.3V @ 20A, +5VSB @ 2.5A
$62: http://www.xpcgear.com/ppcs420x.html
CORSAIR CMPSU-450VX 450W
3.3V@20A,+5V@20A,+12V@33A,-12V@0.8A,+5VSB@2.5A
$60: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
CORSAIR CMPSU-520HX 520W [Modular]
Max. Combined: Acts as a Single-Rail +12V@40A Rated@50C
+3.3@24A,+5V@24A,+12V1@18A,+12V2@18A,+12V3@18A,- 12V@0.8A,+5VSB@3A
$77: http://www.provantage.com/corsair-memory-cmpsu-520hx~7CSMC02X.htm
PC Power & Cooling S61EPS 610W Rated@40C
+3.3@24A,+5V@30A,+12V@49A,-12V@0.8A,+5VSB@3.0A
$70: http://www.newegg.com/Product/Product.aspx?Item=N82E16817703005
For your 1U & 2U, I recommend contacting Zippy USA
When you move to increased hard drive numbers will the controller you choose support staggered spin up of drives at boot? If not you may have to increase the capacity of the PSU to account for this increased peak draw. Something to think about, depending on how many drives you add.
A very good point, as even SATA 7200RPM HDD's can pull close to +12V@3A each at spin-up, but usually use less than +12V@1A during operation.
The tower server will likely never have more than 4 drives in it, so I'll just get a 'known good' power supply. The rack server however, WILL have more than 4 drives in it at some point. I'll probably look to get a 750w+ for it. Is there a difference in quality between server grade and desktop power supplies? It does not seem like it with all of the clean power produced by a nice desktop power supply these days.
I am looking at this rackmount case, based on recommendations I have seen from here.. http://www.newegg.com/Product/Product.aspx?Item=N82E16811219021. It appears to take a standard ATX power supply. I may just go that route.
Nope. If Ockie used a Corsair TX750 for his Galaxy 6.0 build it should serve you well too :)
Thanks. I was wondering which one he had used. I looked for the thread on here (which I remember seeing at one time), but I probably didn't look hard enough. I'm just going to use that same P/S for both builds. It's inexpensive enough and will offer good peace of mind.
Any of these should be fine.
Without "staggered" spin-up, allow for up to +12V@3A per HDD.
PC Power & Cooling S75CF 750W Rated@40C
+3.3V@24A,+5V@30A,+12V@60A,-12V@0.8A,+5VSB@3.0A
$95: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341011
CORSAIR CMPSU-750TX 750W
+3.3V@30A,+5V@28A,+12V@60A, -12V@0.8A,+5VSB@3.0A
$110: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
CORSAIR CMPSU-850TX 850W
+3.3V@30A, +5V30A, +12V@70A, -12V@0.8A, +5VSB@3A
$120: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
Whatever you get make sure it has a Single +12V Rail, as almost all of you power needs to got to powering your HDD's.
