the ocz gamestream power supplies work great and they even have a blue led fan so it matches.
Though the 8? pin motherboard power cable is unfortunately a bit short for boards that have the plug near the top, so it just sits across everything in the case.
I'll second that. I have the 700W in my Antec 900. Though the 8? pin motherboard power cable is unfortunately a bit short for boards that have the plug near the top, so it just sits across everything in the case. Purely aesthetic. Some have mentioned this PSU has some ripple when pushed near its limit, though I have not run into any problems with it
Hi I was thinking about getting the Antec 900, but I was worried about the position of the power supply. I run crossfire and I was worried that if I got a power supply that has a bottom fan that the position in this case would effect the video cards.
