Due to the heat that is making in my country the power supply fan is noisy, there is not a technical failure, sound like air, but still annoying, I have no choice, change psu fan or psu supply.
Current fan specifications are:
Brand: ADDA
Model: AD1212UB-A70GL
Dimensions: 120x120x25 MM
Voltage: DC 12V
Current: 0.50A
Power: 6.0W
Speed​​: 2500 RPM
Air Flow: 98.6 CFM
Noise: 43.3 dBA
Bearing: Ball
Termination: 2-Wire Leads
Now my questions are these:
1) Should I buy a fan with PWM?, in order to the power supply continue doing the speed control?
2) If I buy a fan with 2-pin connector, I can just disconnect the old fan, and plug-in the new one, or should splice and solder anyway with the old connector?
3) And the most important, the current fan is 2500RPM, if I put another fan whose speed is 1500RPM for example, the power supply would force him to go beyond that?
PD: sorry for my bad english.
Brand: ADDA
Voltage: DC 12V
Current: 0.50A
Power: 6.0W
Speed​​: 2500 RPM
Air Flow: 98.6 CFM
Noise: 43.3 dBA
Bearing: Ball
