Power Supply Fan Dying?
Requiem
Back at the beginning of December I bought this power supply, http://www.newegg.com/app/ViewProductDesc.asp?description=17-153-007&depa=0, (Thermaltake Silent Purepower 480W). I first noticed a change in pitch of one of the fans in my case and then narrowed it down to the power supply. The exhaust fan changes RPM very often without me touching the knob. It didn't do this right after I bought it and has recently started. Do I need a new power supply or something?
http://www.thermaltake.com/purepower/W001314.htm
"Temperature Automatic Fan Speed Control"
which could be borked, constantly readjusting itself
alternately it could be perfectly functional, switching on to lower the temperature and then switching off again
Id say try setting the manual fan speed higher and see if it calms down a bit
The reason why I doubt it is changing according to temperature is that it changes at very often and can go from 2500rpm to about 1000 very quicky. Also, it just started happening about a month ago so I doubt it is temperature. I have also tried different speed settings and it still changes speed rapidly.
