dukenuke88
- Jun 22, 2011
Alright heres the story. The system I built back in April has been rock solid. I recently got my GTX 580 SLI system, so I decided to go on a Crysis marathon. Played 1, Warhead, 2, all back to back. When I finally got done with 2, I step outside to get a drink, when I come back my computer is shut off. Not freeze, shut off.
I tried to turn it back on and it just stays at the black screen. No post beep, doesn't go any further. Reset CMOS, still the same. My cold cathode lights turn on and so do all my case fans. Btw all my case fans are connected directly to the PSU, none to the motherboard. The only thing I noticed fishy, my Noctua NH-D14 fans do not spin. And those fans are connected directly to the motherboard. First thing comes to my mind is my motherboard is bad...since my PSU is powering everything else....and yes, I did do this test
http://www.youtube.com/watch?v=5FWXgQSokF4
So anyway I call up Asus, since my motherboard is a P8P67 Pro, I qualify for Asus premium service (basically an advanced RMA)...so right now I'm just waiting for them to send me the paper forms to fill out credit card for collateral. While I'm waiting, I poked around my power supply just to check stuff out and noticed a few things
I noticed my 24 pin, the two plastic housing you see where my index finger is, theres some damage. Also the gold "pins" are further down inside the plastic housing on only these two, and the rest of the 22 pins are equal in depth. Do you guys think my power supply is responsible for my computer not getting into POST? Remember, all case fans and cold cathodes turn on...btw, I'm very careful when handling things...and IMO, its pretty hard to damage the 24 pin unless you are drunk, or purposely man handle the thing into the motherboard...besides, the damage looks more like it "over heated, warped" the plastic, if anything
I looked up on wikipedia, those two yellow wires where the damaged housing, it says its 12V
Thanks in advanced..my PSU is an XFX 850w 80 plus silver
