jgarcia408
- Aug 8, 2004
Hi everyone. I come here every so often cause you guys are awesome when I need a hardware question answered. Anyways. I have a Dell computer. It has a 400w power supply. I only have onboard video right now and want to buy a Nvidia 9600gt card. Well Ive run into a possible problem. It can be minor problem or it can be big, I really dont know. Here it is. Im pressed for cash. I have about $180 I can use right now. Ive been told a 400w power supply will be fine, but the problem is it doesnt have the right connection. There is no 6-pin video card power connector on the power supply. There is also no 4-pin molex connectors. The only connectors that the power supply has are 15-pin Serial ATA power connectors. I dont know what to do. Do I have to wait a little longer until I can get a new power supply or is there some type of adaptor to convert a 15-pin Serial ATA power connector to a 6-pin vga power connector or 4-pin molex power connector?
Can anyone tell me if there is any way around buying a new power supply?
Thanks in advance.
Thanks in advance.
